Imposible SICCG Solution
Andoni Garcia
Andoni Garcia Altair Community Member
edited October 2020 in Community Q&A
Hi!
Someone can help me with this problem?
Solution of linear system by SICCG impossible
 The solving process has probably not correctly converged
Welcome!
Answers
  • fzidat
    fzidat
    Altair Employee
    edited June 2020
    Hello;
    Can you please try to use MUMPs Instead of ICCG, to modefy the solving options, please go to Solving menu, and then solving options.
    However, I think your Flux project is not well defined. There is no magnetic circuit for instance. It can be the case, but if it is, I invite you te create a insulation face region between the green block and the winding.
    The same thing for the coil, as it is defined, Flux will consider the coil as a block with only one turn, in this case also, you should create an insulation face region between each turn to the other.
    Best regards
  • fzidat
    fzidat
    Altair Employee
    edited June 2020
    The insultion face on the winding like this one.
    Regards
  • Andoni Garcia
    edited June 2020
    Thank you Farid Zidat,
    This is the same primary coil's step file solved individually:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.67ee03f69daeb399165c0bdd544b538a.png
    And it's also taken into account that distance in geometry options, but I think that you'd adviced to create the insulation face to have the surety not to occur any short-cut, right?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.29c2660a7ba1193de002b507e4523c73.png
    If you want to check it, you've got the STEP file down below.
    Did you have solved propertly using Mumps instead of ICCG? Not to me:
    CECUVG   => Determinant du jacobien nul
    CECUVW_1 => Failed
    CECUVW   => Failed
    CE2UVW   => failed
    DAV2OC_1 => failed
    FL5ELE_1_1 => Error generating finite elements
    FL5ELE_1 => Failed
    PBCMDO   => Failed
    PBFNUM   => Problem while evaluating. Impossible to solve problem.
    PBERES_3 => failed
    FL5RE4   => Command not executed correctly
    FL5ERS   => failed
    FL5ERS_1 => failed
    executeAlgo_c => failed
    stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
    Failed execution
        at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:153)
        at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
        at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:883)
        at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
        at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2142)
        at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
        at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145)
        at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:302)
        at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2794)
        at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:1972)
        at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2091)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
        at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
        at org.python.core.PyObject.__call__(PyObject.java:526)
        at org.python.core.PyObject.__call__(PyObject.java:532)
        at org.python.core.PyMethod.__call__(PyMethod.java:171)
        at pydb$py.executeMethod$200(pydb.py:1569)
        at pydb$py.call_function(pydb.py)
        at org.python.core.PyTableCode.call(PyTableCode.java:167)
        at org.python.core.PyBaseCode.call(PyBaseCode.java:170)
        at org.python.core.PyFunction.__call__(PyFunction.java:434)
        at org.python.core.PyMethod.__call__(PyMethod.java:156)
        at pydb$py.__call__$167(pydb.py:1342)
        at org.python.core.PyBaseCode.call(PyBaseCode.java:307)
        at org.python.core.PyBaseCode.call(PyBaseCode.java:198)
        at org.python.core.PyFunction.__call__(PyFunction.java:482)
        at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
        at org.python.core.PyMethod.__call__(PyMethod.java:228)
        at org.python.core.PyMethod.__call__(PyMethod.java:223)
        at org.python.core.PyObject.invoke(PyObject.java:3697)
        at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
        at org.python.core.PyInstance.__call__(PyInstance.java:372)
        at org.python.core.PyObject.__call__(PyObject.java:405)
        at org.python.pycode._pyx31.f$0(<input>:1)
        at org.python.pycode._pyx31.call_function(<input>)
        at org.python.core.PyCode.call(PyCode.java:18)
        at org.python.core.Py.runCode(Py.java:1398)
        at org.python.core.Py.exec(Py.java:1442)
        at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
        at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628)
        at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623)
        at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598)
        at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593)
        at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638)
        at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:706)
        at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
        at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(Unknown Source)
        at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(Unknown Source)
        at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:690)
        at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
        at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
        at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
        at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
        at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
        at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
        at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
    Thanks for your help,
    Andoni
Welcome!
Welcome!
