I am using the full vehicle with driver.
and have gone through the help files available.
To perform various maneuvers I have edited the .adf file for event altairdriverfile, in the .txt format and then inserted it from the event editor tab.
For the .adf file I copied a existing .adf file from Altair library (Straight Line Braking) and then added the following from 3D spline road data file available in the help section.
$-------------------------------------------------------------------------END_DATA_POINTS [OBSTACLE1] ROAD_TYPE = 'PotHole' COORDINATE_SYSTEM = 'distance' START = 0.7 LENGTH = 1.5 DEPTH = -0.007 $-------------------------------------------------------------------------END_OBSTACLE1 [OBSTACLE2] ROAD_TYPE = 'Curb' HEIGHT = 0.05 START = 0 ROUND_OFF = 3.99805 TOP_WIDTH = 1 EDGE_WIDTH = 3
But it only performed the straight line braking.
How do I insert the code for it? ( I want to add a few bumps and drops)
