🎉Community Raffle - Win $25
Join and Win
Symmetry with RBE3 element
mansinUser: "mansin"
Altair Community Member
Updated by mansin
Hi,
I have a problem with planar symmetry on a tube. One end of this tube is full constrained, the distributed force on the other end is applied by the concentrate force (or torque) on dependent node of RBE3 element. To reduce the model, a quarter of this tube is constructed. For the nodes on symmetry plane (X-plane and Y-plane) except the dependent node of RBE3 element, the (156 and 246)DOFs of these nodes are constrained. The model is shown as follow: (Fz=1000, Tz=2000)
 image.png.937e1b55a51655ba6beca8a46d02087f.pngimage.png.a26c308b3f79a1b925972bcefaadb3a7.pngimage.png.33eb4293c52b5cb10303485d739308ae.png
However, the results of the two loads are not reasonable and right.
image.png.2be12d4820ee5d202f5defa919fb69d4.pngimage.png.48fc7ff4c449f17cdcfa7173f7d37437.png
I think the reason is the symmetry constraint of RBE3 element is not setup correctly. How to fix it?
I attach the results of the whole model (Radius=20, length=200, Thickness=2, Fz=4000, Tz=8000):
image.png.d4ad1de09ac229b4e78dd24bb89212e4.pngimage.png.c8b844599d0e47de697cf54a31247a43.png
1 - 9 of 91
