1 - 7 of
71
the textbox next to DOF is used to input enforced displacement value.
check the following video where it is used at 6:37
What does this size value indicate while creating a constraint for certain nodes in HyperMesh ?
Hi JCD
The size value just means the dimension of the graphic symbol of the constraint (in model units).
Also, Whats the use of values near to dof1, dof2, .. And so on.?
Its a constraints why they are in need of magnitudes?
When you have value = ZERO => that's 'NULL' constraints (fixations).
But when you have value != ZERO => that's 'PRESCRIBED' contraints
Thank you.
I tried and I got it.
Thank you.
Can you please explain again I didn't get the use of textbox in front of the DOF.
Hi JCD
