🎉Community Raffle - Win $25
Join and Win
Problems transferring material data
User: "Nguyen Khoa_21958"
Altair Community Member
Updated by Nguyen Khoa_21958
I am doing a project that need different materials, I am transferring my material data and got this problem, or sometimes it just crashed?
Is there anyway to solve it, Thanks!
1 - 2 of 21
    User: "Stephen Cole"
    Altair Employee
    Accepted Answer
    Updated by Stephen Cole
    Hi,
    It seems like either the mateiralsDB.h5 file either isn't in the Documents folder or you don't have read/write permissions for this folder.
    If you don't have permissions or the folder doesn't exist you can change the location via EDEM Tools > Options > File Locations
    Otherwise you can copy the original database file from C:\Program Files\Altair\2022.3\EDEM\docs to your my documents folder or elsewhere and try copying to that.  Just to note don't set the location to be in "Program Files" as standard you don't have write access to that location , it's best to copy the files out to another place.
    Regards
    Stephen
    OP
    Hi,
    Regards
    Stephen
    I copied the original database and it worked. Thank you!
