Hello everyone,
I am a new comer of Altair community.
Recently I am trying to learn FEKO of Altair.
I started with a very simple example, modelling a commonly used antenna radiator, which is a WR-90 waveguide (22.86mm*10.16mm) with one end embedded in a infinite PEC ground to radiate energy into half free space. When I complete the model and try to find its far field 3D pattern with the fundamental TE10 mode as excitation, a error box appears, which says
"The following message from the master process (MYID= 0):
ERROR 270: A triangle may not be located in the ground"
I have attached with this question the .cfs file of the model, could anyone help me to to find out the mistakes?
Thank you very much!
