Steady State Heat transfer
How to provide heat transfer between two blocks seperated by some gap ....
I have tried TCID and KOHTC entries in PCONTHT Property.
My main concern is to find out heat transfer amount between gap (between two blocks ) .... Should not use mesh or gap elements in that gap ....
Finally I got some results ... Same way I have tried with various gaps but results are not changed with respect to various gaps.
1 - 1 of
11
Also How to check the heat out (power) from the blocks . I have not mentioned applied power.
