Hi everyone,
In HyperWorks 2019.1.1 version (HyperForm Radioss Incremental interface) i have faced some errors as you can see them below in images and descriptions.
I use automated process tools.
After preparation of the model, materials have 7.8e-8 density value which must be 7.8e-9 in MPa unit system.
Is this change normal in automated process to increase timestep of model?
In addition to this issue, after automated model preparation Begin Card has correct value of mass which is Mg.(tonne) When i export manually .rad file, Begin Card has incorrrect mass unit which is mg.
Could you investigate these unexpected issues?
Thank you.
