Is it posible to use elements not associated with any geometry as seed when meshing a solid? Could I associate nodes to a body face so the new mesh would follow the pattern of the nodes?
if you have an orphan mesh, you could associate its nodes to a geom in the 'node edit' panel, using the option 'associate'.
