Problem Using MonarchObj.SETRUNTIMEPARAMETER in Dropbox
Hello All:
I am having no success using the MonarchObj.SETRUNTIMEPARAMETER function with the COM scripting in Dropbox environment. No Error message is popped, but the result is not accomplished. However, when I run the same COM scripting in stand alone pc environment, the results are achieved.
Is this a bug using Monarch COM in the Dropbox, or am I approaching the requirement in wrong way. I have attached my COM script and would appreciate any help. Please advise if I should post a support ticket on the Altair support site.
Thanks
Al Rice
Trends In Data, LLC
(248) 761-5238
Hi Al,
I have forwarded your question to DA Technical Support - DASupport@altair.com on your behalf and you should receive direct email correspondence from them. Thank you for your patience & understanding.
