Is there any problems with ERR % -99.9 when rayleigh damping is applied?
Hi,
I applied rayleigh damping using /DAMP
Result is as follows.
NC= 0 T= 0.0000E+00 DT= 6.0221E-07 ERR= 0.0% DM/M= 0.0000E+00
NC= 500 T= 2.2232E-04 DT= 4.4566E-07 ERR=-32.8% DM/M= 0.0000E+00
ELAPSED TIME= 2.12 s REMAINING TIME= 19105.88 s
NC= 1000 T= 4.4058E-04 DT= 4.3447E-07 ERR=-37.1% DM/M= 0.0000E+00
ELAPSED TIME= 2.55 s REMAINING TIME= 11554.85 s
NC= 4673500 T= 1.9996E+00 DT= 4.4771E-07 ERR=-99.9% DM/M= 0.0000E+00
ELAPSED TIME= 4238.97 s REMAINING TIME= 0.82 s
NC= 4674000 T= 1.9998E+00 DT= 4.4771E-07 ERR=-99.9% DM/M= 0.0000E+00
ELAPSED TIME= 4239.43 s REMAINING TIME= 0.34 s
Because of damping,
Does this result seem to be no problem?
Thanks
Negative energy error can be reasonable depending on your model. A negative energy error makes sense when you have things like friction or damping. What I think may be happening is your damping is so high it is absorbing all the energy, so double check your values for damping.
