Hi,
I am performing a transient Direct analysis, for an sub assembly.
In which I need to model a non linear spring. Generally we will give Non Linear spring in Static Non Linear analysis using NLPRAM card.
But here I don't see any options for that. Please help me on this.
hi,
Transient Direct that you're using is targeted for Linear analysis, thus the non-linear spring could not be used.
For NL effects, a nonlinear transient analysis should be used.
