🎉Community Raffle - Win $25
Join and Win
CAN MACROS/COMMAND FILE/TCL BE RUN IN BATCH MODE?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am new to hypermesh and have just started learning it as need for an application.
I wanted to modify a FE model by running hypermesh in batch mode. For this kind of application what is preferable ? and how to do it?
1 Through running macros in batch mode
2 running command file in batch mode
3 writing tcl script
what will be the difference between them?
thanx,
1 - 1 of 11
    Altair Employee
    OP
    Hey Sven,
    I got your point. Thanx a lot for explaining this. Here is what I am trying to do and I was confused about.
    I wanted to run hypermesh to modify mesh of some objects and to do certain morphing operation which may turn out to be an iterative procedure.
    While going through the hypermesh I came accross 3 options of doing it viz writting a 'C' prog, loading a command file and writting tcl script. So I thought, first option is a batch mode operation.
    I will be thankful to you if you can help me by telling a step by step procedure of running hypermesh by writting a 'C' program, I couldnt get it through hypermesh help.
    With thanks,
    keepingbusy
