Speeding up the node selection process
User: "Spedex"
New Altair Community Member
Updated by Spedex
Hello everybody,
I am using HyperWorks Desktop 2022 (Student Version). When I want to select a node from a mesh that I have created, the program does not react anymore for many seconds until it has selected the node.
Here is a video that shows it:
https://streamable.com/4eyat5
Funnily, if I select the node with "Shift"  + "Left Mouse Button", it works immediately.
https://streamable.com/94vd32
My working device uses an Intel Core i7-9850H with 12 x 2.6 GHz, which is not too bad. Colleagues of mine have worse specs and still don't run in this issue (while still using the same software and version).
Does somebody know if I am doing something wrong or how to fix it?
Greetings
Spedex
PS: Both videos are added to the attachments as well.
1 - 1 of 11
