🎉Community Raffle - Win $25
Join and Win
Periodic Mesh 2D
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hallo,
I have a mesh of 2D Shell elements (like a disk). I would like to apply periodic boundary conditions to the model. But HyperMesh supports only periodic meshing for 3D models (periodic mesh utillity). Is there any possibility to have periodic boundary conditions based on nodes or something else?
F.M.
1 - 4 of 41
    Altair Employee
    OP
    Hi fabian0989
    You can use PERBC card which is available in HW 13.0.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-14772000-1416564220_thumb.jp
    Altair Employee
    OP
    Thanks a lot!
    I will try.
    Is this option available for Optistruct only or also for RADIOSS?
    F.M.
    Altair Employee
    OP
    Hi, where and how can I use Perbc? Where can I find this button or command?
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi ttn@tf.uni-kiel.de
    The PERBC bulk data entry can be used to define a connection between opposite edges/faces of the structure. This entry is used to apply Periodic Boundary Conditions to the model.
    You can define it from Analysis > control cards > bulk_unsuppported_cards.
    Refer online help for more details.
