🎉Community Raffle - Win $25
Join and Win
Plot beam stress
Hi everybody
I'm using radioss (bulk format) to do some Beam/shell static analysis.
I've tried to plot cbar/cbeam stresses in the hyperview but it seem that for 1D elements it only shows stresses due to axial forces not bending moments.
how can I plot contours for bending stresses?
I'm using hyperworks 11
1 - 6 of 61
    Hi everybody
    you could check the radioss manuals for your desired outputs about stress plots
    by the way be sure about your beam is euler-bernoulli
    The beam is CBEAM which is timoshenko beam.
    Manual is not clear about that.the STRESS card control outpot but it has no effect on 1d element. I can plot element forces not stresses.While ANSYS plot von misses stress even for beams I wonder why hyperworks can't do such simple thing.
    alpha_21885User: "alpha_21885"
    Altair Community Member
    Updated by alpha_21885
    Hi Mechalizar,
    I think there is no actual VonMise stress contour for bending bar/beam elements only. Absolutely, you can extract or see the bending stress in HyperView: Element stress(1D) --> Cbar/cbeam long. stress SAC, SAD,SAF,SAE. However, you must define C,D,E,F point in HyperMesh( Card edit Bar/Beam Properties --> Check ON 'CONT1' then input C(x,y), E(x,y), D(x,y), F(x,y)) before submitting jobs on Optistruct.
    Rahul_P1User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    In OptiStruct v13.0, CBAR/CBEAM(PBARL/PBEAML) Stresses at evaluation points are output separately (different from PBAR/PBEAM-element) in H3D file. When you load h3d result file in HyperView, you can see a new result type like 'CBAR/CBEAM Stresses (BAR)', 'BAR' in the parentheses is the type name of beam cross section. That means each cross-section type has its own result group.
    And you can review all the evaluation stresses (normal, shear, and von Mises) for each cross-section type, at each element end (A or B.
    For instance,
    Normal S3N(B : means normal stress at the 3-th evaluation point of the beam element end B;
    Shear S6S(A)  : means shear stress at the 6-th evaluation point of the beam element end A;
    von Mises S5V(B : means von Mises stress at the 5-th evaluation point of the beam element end B.
    And you can see maximum normal/shear/vonMises stress at the end
    Hi, I cannot get displayed the beam stresses in HyperView. I have used CBEAM elements. I see the options to display the result type but when I select 'CBAR/CBEAM Axial/Long. Stress SAC/SAB/..../SAMIN/....' they are all zero.
    They are obviously either not calculated or not output. What do I have to do?
    Do anyone know how to find out bending stress?
