Has flux any tool to consider coil additional losses?
Hello,
I have a question about calculating coil losses in transformer and core inductance applications. Has flux any tool or way to get this coil losses. This losses are produced by the joule effect that I am able to calculte and also other additional losses. My question is about getting this additional losses. Is any way to get this losses in flux?
Thank you,
Iñigo Izaguirre
1 - 5 of
51
Hi,
generally, the losses in winding are divided into two parts:
In Flux, yes there is a way to consider of the AC losses. This option is available in steady state AC application.
In the supervisor there is an example showing how you can consider this type of losses.
Thank.
