🎉Community Raffle - Win $25
Join and Win
ERROR : RUN NAME IS NOT DEFINED
User: "Wisawanart"
Altair Community Member
Updated by Wisawanart
Hi Support Team
      I have tried to run the simulation model including the residual stress (.sta). I set the stress into the model using Results Initializer from the Crash interface, unfortunately, I face MASSAGE ID : 194
ERROR : RUN NAME IS NOT DEFINED.
      Before the residual stresses are taken into account, the solver operates properly. Even though, I have already filled up all of blank which is related to 'RUN NAME' but still fail.
How to fix this issue?
Best regards.
Wisawanart
1 - 1 of 11
    User: "gopal_rathore"
    Updated by gopal_rathore
    Hi,
    Check your engine file. Run name might be missing int it. You can give this through engine control card
