🎉Community Raffle - Win $25
Join and Win
Creating Assembly Hierarchy from Excel and Script
Hi Experts,
I want to automate the assembly creation, I can go in 2 ways.
1. Create an assembly hierarchy in excel file and use the script to implement in my hm file.
2. Create a script to create the assembly hierarchy in hm itself using the user input (selecting the sub-assemblies and components together to form an assembly).
Which option would be easier and feasible.
I am just a beginner in TCL.
Thanks in advance!!
1 - 5 of 51
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    Hi Experts,
    Thanks in advance!!
    Hi,
    both are feasible, option (2) is easier because it does not have to parse the excel file
    Thanks a lot for the info!!
    I`ve started working on it but I want to know the command for either of these
    1. How to get the assembly ID of a component.
    2. How can I get the list of component ID's in an Assembly.
    Please share.
    Thanks and Regards
    Harmeek
    tinhUser: "tinh"
    Updated by tinh
    Hello
    - to get assembly IDs of a component (not unique, because one comp can belong to several assems)
     *createmark comps 1 'by id only' $CompId *findmark comps 1 1 1 assems 0 2 set AssemIdList [hm_getmark assems 2]
    - to get comp IDs in an assem:
     set CompIdList [hm_getvalue assems id=$AssemId dataname=components]
    Hello,
    I am trying to isolate/show assemblies but when I use
    *startnotehistorystate {show Assembly}
    *createmark assemblies 2 $isolate_assembly
    *createstringarray 2 'elements_on' 'geometry_on'
    *showentitybymark 2 1 2
    *endnotehistorystate {show Assembly}
    it dosen't work, but instead of variable if I use assembly name directly it works.
    Am i missing out something? But using variable name for components worked well.
    Sorry my bad...it worked...
