Creating Assembly Hierarchy from Excel and Script
Hi Experts,
I want to automate the assembly creation, I can go in 2 ways.
1. Create an assembly hierarchy in excel file and use the script to implement in my hm file.
2. Create a script to create the assembly hierarchy in hm itself using the user input (selecting the sub-assemblies and components together to form an assembly).
Which option would be easier and feasible.
I am just a beginner in TCL.
Thanks in advance!!
Thanks a lot for the info!!
I`ve started working on it but I want to know the command for either of these
1. How to get the assembly ID of a component.
2. How can I get the list of component ID's in an Assembly.
Please share.
Thanks and Regards
Harmeek
Hello
- to get assembly IDs of a component (not unique, because one comp can belong to several assems)
*createmark comps 1 'by id only' $CompId *findmark comps 1 1 1 assems 0 2 set AssemIdList [hm_getmark assems 2]
- to get comp IDs in an assem:
set CompIdList [hm_getvalue assems id=$AssemId dataname=components]
Hello,
I am trying to isolate/show assemblies but when I use
*startnotehistorystate {show Assembly}
*createmark assemblies 2 $isolate_assembly
*createstringarray 2 'elements_on' 'geometry_on'
*showentitybymark 2 1 2
*endnotehistorystate {show Assembly}
it dosen't work, but instead of variable if I use assembly name directly it works.
Am i missing out something? But using variable name for components worked well.
Hi,
both are feasible, option (2) is easier because it does not have to parse the excel file
