🎉Community Raffle - Win $25
Join and Win
Mesh at Midsurface techniques ??
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi all...
when it becomes impossible to extracting midsurface using 'Auto Mid-surface' or 'Surface-pair' options for a complicated varying thickness plastic component
, what is the best way to get a mesh at middle of the section ???
i have been extracting lines and creating midlines and meshing with 2D manual mesh, which is laborious process indeed... is there any other option to achieve midsurfaces ????
thanks in advance... image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
1 - 6 of 61
    User: "tinh"
    Altair Community Member
    Updated by tinh
    hi
    i think hm12 improved midsurface function a lot
    so if your component is extremely complex, it's minority so try to create midsurface manually ( make mid line, using ruled, drag,..., or create nodes and nodes and move them
    litle by litle...)
    have a good job
    Altair Employee
    OP
    thanks for the reply...  image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Altair Employee
    OP
    When mid-surface function of HW can not help, you have to create that manually.
    Altair Employee
    OP
    @ Q.NGUYEN-DAI : thank you for the reply sir....
    Altair Employee
    OP
    Surface pair means it's manually midsurface?
    User: "Simon Križnik"
    Updated by Simon Križnik
    @Ravikumar nelwale
    The surface pair can be found in geom>midsurface>final edit tools>surface pairs. The mid surface is created by manually picking a pair of surfaces. There is also some additional functionality, see the attached image (from HM help):
