🎉Community Raffle - Win $25
Join and Win
Create either a tetra element or a pyramid element
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Create either a tetra element or a pyramid element using the original element node list and the new node created by the script.
1 - 2 of 21
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Look like .... homework ???
    User: "Pandurang"
    Updated by Pandurang
    Help me to Create a node at the centroid of the element. Translate the node in the positive direction of the element normal by an amount equal to the shortest diagonal of a quad element and the shortest side of a tria element. Create either a tetra element or a pyramid element using the original element node list and the new node created by the script.
    Hi,
    Please try this:
    *createmarkpanel elems 1 'Select elements'
    set elem_id [hm_getmark elems 1]
    *clearmark  elems 1
    set config [hm_getentityvalue elems $elem_id config 0]
    # element normal
    set elem_normal [hm_getelementnormal $elem_id edge 1]
    #node list
    set node_list [hm_getvalue elems id=$elem_id dataname=nodes];
    # centroid
    set centerX [hm_getentityvalue elems $elem_id centerx 0]
    set centerY [hm_getentityvalue elems $elem_id centery 0]
    set centerZ [hm_getentityvalue elems $elem_id centerz 0]
    #create node at Center
    *createnode $centerX $centerY $centerZ 0;
    #translate node
    *createmark nodes 1 -1;
    set center_node [hm_getmark nodes 1]
    # create vector
    *vectorcreate 1 {*}$elem_normal 0;
        switch $config {
            104 {
                set Short_dia [hm_getentityvalue elems $elem_id shortestdiagonal 0]
                *translatemark nodes 1 1 $Short_dia;
                #create pyramid
                *createlist nodes 1 {*}$node_list $center_node
                *createelement 205 1 1 1
            103 {
                set Short_side [hm_getentityvalue elems $elem_id shortestside 0]
                *translatemark nodes 1 1 $Short_side;
                #create tetra
                *createelement 204 1 1 1
    *clearmark  nodes 1
    *clearlist nodes 1
    #delete vector
    *createmark vector 1 -1;
    *deletemark vector 1
    *nodecleartempmark
