How to connect 2d shell to 3d solid ? is there any best practice to follow ? Currently have connected both shell and solid with 0.01 mm shell elements.
User: "Sivadas"
Altair Community Member
Updated by Sivadas
1 - 1 of 11
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    it really depends on what you're trying to model and what connection type you're representing. You could simplify things depending on the case.
    You could use a TIE/FREEZE contact also for connecting these dissimilar meshes. I'd say that it really depends on the stiffness of your physical connection.
