🎉Community Raffle - Win $25
Join and Win
Extraction of vector plots for 1 elements
User: "kandiyal"
Altair Community Member
Updated by kandiyal
Hi,
I Have CBush and CBar elements in my fem model, want to extract vector plots for fasteners I have tried with below  command options in different run but none of them work
ELFORCE(OPTI) = ALL
ELFORCE= ALL
GPFORCE=ALL
FORCE(OPTI)=ALL
Kindly let me the command to get desired output. It will be helpful if you share any tutorial on same problem.
Regards,
Kandiyal
1 - 2 of 21
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    In HyperView for loading the model, are you loading the .fem as the model, and the .op2 for the results? Also are you setting the Results-Math template = Advanced?
    When you do this, I think you should able to plot 1D element forces and moments.
    User: "kandiyal"
    OP
    Updated by kandiyal
    Thanks For your valuable suggestion.
    Regards,
    Nitin
