Export defined group of Surface/Mesh into Abaqus
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have defined a red surface in the purple plate in the HyperMesh.
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-26244000-1445051785_thumb.j
Later I plan to export the tetramesh and red surface into Abaqus for analysis. A pressure would be loaded on the red surface
<?xml version="1.0" encoding="UTF-8"?>post-39070-0-09864300-1445051800_thumb.j
After exported into Abaqus, there is no more surface component any more.
I am wondering how should I get a defined surface in HyperMesh and use it in Abaqus?
Thank you!
Attached is the file but .txt should be converted back to .hm
