1 - 7 of
71
Hello,
I want to know how to integrate kinematic conditions in Hypercrash
thank You /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
I mean the connections between the different parts.
sliding connection, revoluted...
Thank you
Okay, sorry I thought you want to create kinematic boundary conditions.
If you want to create contacts go to LoadCases>> contact interface.
is there a worshop where we can define the kinematic pairs ( revolute, prismatic...)?
Thank you /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
You can apply cylindrical joint using HyperCrash,
If you are specific about re volute joint, what you can do is constraint using kinematic BC and leave the rotational DoF of desired direction.
I want to apply the cylindrical joint, but I have no idea about the parametres that I have to define such as:
sttifness, critical damping factor...
Thank you
Hi,
Cylindrical joint in RADIOSS behaves like a rigid body.
Hi,
In HyperCrash, Goto LoadCases>> Boundary conditions.
