Intersection Command Error
User: "seyilmaz"
Altair Community Member
Updated by seyilmaz
Hello,
I try to create two nodes through intersection of a line and a solid. When the solid lies in the planes XY, XZ or XY there is no problem but when the solid is rotated for example 30 degrees then only one node is created. I tried to explain with pictures. Do you know how to solve the problem?
Regards,
2124483426_Gorsel3.png.b2efdc12ea0ace61d8579d4dfa80306b.pngGorsel.png.09e0a85a60660d849967734acd9adc75.png
1 - 9 of 91
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi seyilmaz,
    I think one node must be covering/overlaying on other, when you are viewing from that angle. Please can you check again and make sure.
    Thank you
    User: "seyilmaz"
    OP
    Updated by seyilmaz
    Hello Premanand,
    Thank you for your answer, but when I tried from different view angles still 1 node created only.
    On the other hand, I am working on a script so the viewing direction does not really matter for me.
    Thank you
    Altair Employee
    Can you go to Tool page > numbers > nodes All > and cross check, how many nodes are created.
    Thank you
    User: "seyilmaz"
    OP
    Updated by seyilmaz
    Only one is created.
    Altair Employee
    Please can you share your model
    Thank you
    User: "seyilmaz"
    OP
    Updated by seyilmaz
    User: "seyilmaz"
    OP
    Updated by seyilmaz
    I use the following commands to search for interactions for each surface but this gives and error when I call from a tcl file.
    *createmark surfs 1 'all'
    set surflist [hm_getmark surfs 1]
    foreach surfid $surflist {
    *createmark lines 1 1
    eval *createmark surfs 2 $surfid
    *nodecreateatintersection lines 1 surfaces 2 0
    User: "tinh"
    Updated by tinh
    Hi
    Use catch cmd
    catch {*nodecreateatintersection lines 1 surfaces 2 0}
    User: "seyilmaz"
    OP
    Updated by seyilmaz
    Hello tinh,
    catch command made it work perfectly fine. Thank you very much!
    Regards,
