Intersection Command Error
Hello,
I try to create two nodes through intersection of a line and a solid. When the solid lies in the planes XY, XZ or XY there is no problem but when the solid is rotated for example 30 degrees then only one node is created. I tried to explain with pictures. Do you know how to solve the problem?
Regards,
