🎉Community Raffle - Win $25
Join and Win
Invalid AcuRun path
User: "Ahmed Rami"
Altair Community Member
Updated by Ahmed Rami
My name is Ahmed Rami, I am a student at Universiti Teknologi PETRONAS. while I was using Altair Hyperworks CFD to do some simulations I faced a problem I couldn't solve by myself. As I am trying to run the simulation on Altair Hyperworks CFD I got the error of Invalid AcuRun path.
I tried solving this problem with the same method used in the following link but it still didn't work or I wasn't able to make it work.
https://community.altair.com/community?id=community_question&sys_id=c14081821b040d14507ca6442a4bcbb3
1 - 3 of 31
    User: "Alexandru-Ionel Constantin"
    Updated by Alexandru-Ionel Constantin
    Hi Ahmed Rami,
    You need to set acuRun.bat path for the AcuRun path.
    Best regards,
    Alexandru
    User: "Ahmed Rami"
    OP
    Hi Ahmed Rami,
    Best regards,
    Alexandru
    I tried  doing that and now it says "Failed to run AcuSolve. Check path and arguments" at the bottom of the left hand side.
    I can't couple Edem and Acusolve unless i do it and for some reason it's not working
    User: "acupro"
    Altair Employee
    Updated by acupro
    I would recommend not using spaces - neither in problem name nor in any directories including the problem directory.
