My name is Ahmed Rami, I am a student at Universiti Teknologi PETRONAS. while I was using Altair Hyperworks CFD to do some simulations I faced a problem I couldn't solve by myself. As I am trying to run the simulation on Altair Hyperworks CFD I got the error of Invalid AcuRun path.
I tried solving this problem with the same method used in the following link but it still didn't work or I wasn't able to make it work.
https://community.altair.com/community?id=community_question&sys_id=c14081821b040d14507ca6442a4bcbb3
Hi Ahmed Rami,
You need to set acuRun.bat path for the AcuRun path.
Best regards,
Alexandru
Hi Ahmed Rami, You need to set acuRun.bat path for the AcuRun path. Best regards, Alexandru
I tried doing that and now it says "Failed to run AcuSolve. Check path and arguments" at the bottom of the left hand side.
I can't couple Edem and Acusolve unless i do it and for some reason it's not working
I tried doing that and now it says "Failed to run AcuSolve. Check path and arguments" at the bottom of the left hand side. I can't couple Edem and Acusolve unless i do it and for some reason it's not working
I would recommend not using spaces - neither in problem name nor in any directories including the problem directory.
