HyperMesh 2019 Assembly View
Hi all,
After upgrading from 2017 to 2019, I've noticed that in the standard model browser window under 'Model View', you can see any assemblies but they do not expand in that pane. Instead you need to double click or go to 'Assemblies view'.
The only issue with this, is that the 'Assemblies View' only contains components and not groups etc.
Is there a setting to behave like 2017 and allow the assemblies in 'Model View' to expand?
Many Thanks
2019 - 'Model View' Unexpandable
2017 'Model View' - Expandable
2019 'Assemblies View' - No Groups or Properties etc
