Altair RISE
Nominate Yourself Now!
HyperMesh 2019 Assembly View
User: "ezzymn"
New Altair Community Member
Updated by ezzymn
Hi all,
After upgrading from 2017 to 2019, I've noticed that in the standard model browser window under 'Model View', you can see any assemblies but they do not expand in that pane. Instead you need to double click or go to 'Assemblies view'.
The only issue with this, is that the 'Assemblies View' only contains components and not groups etc.
Is there a setting to behave like 2017 and allow the assemblies in 'Model View' to expand?
Many Thanks
2019 - 'Model View' Unexpandable
2017 'Model View' - Expandable
2019 'Assemblies View' - No Groups or Properties etc
1 - 30 of 341
    User: "tinh"
    Updated by tinh
    That is an inovation of a certain altair's developer :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
    User: "ezzymn"
    OP
    Updated by ezzymn
    Thanks tinh,
    I had feared as much, but hopeful that there was a checkbox lying around somewhere
    User: "tinh"
    Updated by tinh
    Yes, you can right click on model view and a menu item will lead you to a dialog where you can tick on a check box to show assemblies
    User: "ezzymn"
    OP
    Updated by ezzymn
    That's the configuration browser isn't it?
    So that allows me to see / hide assemblies within the model view, but not the ability to expand assemblies within the model view
    User: "tinh"
    Updated by tinh
    Yes could you try it?
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Yes, this is an 'idiot' feature of version 2019
    User: "ezzymn"
    OP
    Updated by ezzymn
    Hey Tinh,
    Tried that, and it doesn't do as we want I'm afraid.
    Another little thing I've just noticed. Everytime you go to the 'Assembly Viewer', it switches the mesh view to 'By Assem', which is rather annoying...
    User: "tinh"
    Updated by tinh
    Hi
    When you enter the dialog 'browser cinfiguration', did you see any check box named 'Assembly Hierarchy'?
    Or you just see 'Assembly'?
    Sorry to ask too detail because I don't have hm2019.
    User: "Rahul Rajan_21763"
    Updated by Rahul Rajan_21763
    Dear All,
    Please check below video to gain benefit, if you use the Part-Browser instead of assemblies.
    User: "ezzymn"
    OP
    Updated by ezzymn
    Hi Rahul,
    Thank you for the video, I learnt things that I wasn't expecting.
    But the problem still stands - I can't open the part browser in the other side, as we have our utility menu there.
    The Assemblies don't expand in the Model Browser
    The Part Assemblies don't expand in the Model Browser.
    The solution of opening another view on the right task bar just won't work for what we do.
    @tinh - Enitities - Assemblies
    User: "Joe Kovacs_22609"
    Altair Employee
    Updated by Joe Kovacs_22609
    Hi @ezzymn,
    You can disable auto color by entity type in the Browser Configuration dialog.  Uncheck 'Autocolor visualization mode' under Local Options.
    It is worth noting that Assembly View of Model browser shows only Assemblies and Components, so it is not possible to interact with entities such as Groups, Properties and Materials.  In Part browser, dedicated columns show you the Component, Property and Material associated with the Part.  See the image below:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.540bd5c88dc6ce5841c115e38966cc74.png
    Since Parts may not be relevant to your workflow, feel free to contact me via DM so I can learn more about your use case and offer additional assistance.
    Cheers,
    Joe
    User: "tinh"
    Updated by tinh
    I thought so.
    Could you please open command window (menu Views>command window) and then enter below command:
    set ::env(HMBR_CONTENT_HIDE_ASSEMBLYHIERARCHY_FOLDER)
    and then take a screenshot?
    I want to see the settings on hm2019
    User: "tinh"
    Updated by tinh
    Hi @ezzymn
    I seem to find out where the settings can be customized.
    It's exactly stored in below files:
    <install dir>/hm/scripts/br/views/model/regular/
    Please copy the folder 'regular' and zip it then post it here. I will modify settings and send back to you.
    Don't modify it by yourself because it's easy to be fault.
    User: "ezzymn"
    OP
    Updated by ezzymn
    Hi @tinh
    can't read '::env(HMBR_CONTENT_HIDE_ASSEMBLYHIERARCHY_FOLDER)': no such variable
    I feel like the functionality might be removed, but I appreciate you having a look. I've tried the crude attempt to copy over the 2017 files, but that segmentation faulted.
    Many Thanks
    Eric
    Altair Employee
    @ezzymn
    As you have correctly deduced, there is no option to show the Assembly hierarchy in 2019.  Depending on the version of 2019 you are using, I can provide a patch that brings back legacy behavior - let me know if you are interested.  As mentioned in my previous post, I am still keen to meet to discuss our the paradigms and workflows we have in 2019.
    As a FYI, legacy behavior will return in 2020.  Additionally, Part hierarchy has never been shown in Model View, though this may change in the future.
    User: "tinh"
    Updated by tinh
    Hi @tinh
    Many Thanks
    Eric
    Hello
    I modify some things
    Please copy these modified files and overwrite the old ones
    If something's wrong, simply backup original files and let me know issues
    User: "ezzymn"
    OP
    Updated by ezzymn
    @tinh, Thank you I'll try and find some time today to try it.
    @joek, Sorry I haven't been ignoring you. I'll give this try from tinh a go, and if that doesn't work then a patch would be much appreciated
    Hi @tinh, it works ! Thank you!  :P/emoticons/default_tongue.png' srcset='/emoticons/tongue@2x.png 2x' title=':P' width='20' />
    Hi @tinh, in 'Assemblies view' I can create Assembly/Component within each Assembly:
    But with 'Model view' (your modified version) I can not do that (maybe the same issue in initial version):
    Do you think it's possible to customize this context menu by adding 'Create ...' ?
    Thanks,
    User: "tinh"
    Updated by tinh
    Yes, I do.
    I will try hooking the menu. Just need a little time to find where it is.
    User: "Burner2k"
    Updated by Burner2k
    @joekI know you guys don't like to discuss product road maps on a forum like this, but will be there be another major dot release of 2019 HW suite (like 2019.2) before arrival of 2020 release (if we go by 2019 release time frame, it could happen almost 5-6 months in to next year)? There are lot of bugs and features missing, especially in HWX. I realize not all can be added or rectified but I am hoping for another major dot release to make HWX little more usable until 2020 release.
    Thanks...
    User: "tinh"
    Updated by tinh
    I deem persons before become HM developers should be HM users, so they could upgrade software better. Anyway it's a really good software because we can do almost things by Tcl ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
    I deem persons before become HM developers should be HM users, ....;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
    Yes, it's the ideal case. But in reality, that is not always true.
    The 'Model view' of 2019.0 & 2019.1 (with useless Assembly tree)  is a typical example of developers who don't take care of what users want.
    User: "tinh"
    Updated by tinh
    Yes, I do.
    Hi Mr. @Q.Nguyen-Dai
    I seem to find it in hm2017
    I don't have hm2019, could you please zip folder <install_dir>/hm/scripts/br  and post here.
    In your gmail box :-)
    User: "tinh"
    Updated by tinh
    :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> it is quite similar to hm2017
    I am sure that context menu settings of modelview are stored in .../br/views/common/menucreate.xml
    There are 3 menu items existing in that file: Assembly, Component, Multibody
    Same as hm2017
    Could you try closing HM, delete hmsettings.tcl , hmmenu.set then open it again.
    Other tests:
    1) right click on a white space to see full menu 'Create', are there Assembly, Component, Multibody in the menu?
    2) check if it is invisible by enter to cmd window:
    ::hmbr::createentity::isVisible Assemblies content ::hmbr::createentity
    above should return 'true'
    If it returns 'false', we will debug it later.
    User: "tinh"
    Updated by tinh
    Before enter the command, pls left click on an assembly on modelview.
    User: "tinh"
    Updated by tinh
    Hi,
    I think I found it.
    In file .../br/common/operations/createentity.tcl
    Please open it and go to line 70:
    if { $types == 'Assemblies' && $view == 'assemhierarchy' } {
    Please change it to be same as hm2017:
    if { $types == 'Assemblies' } {
    In hm2019 the line indicates that only assemblyview will show menu items Assembly, Component, Multibody
    Wow, wonderful!
    Thank you!
    @tinh : Could you do the same customization for Hyperview? Thanks
1 - 30 of 341
