optistruct stops with no warnings or errors What next? - SOLVED
I've set up my model in Hyperworks 2022, used Validate->Model to remove all warnings and errors.
On running I get only this in the .out file (how do I find the error?)
** Altair OptiStruct(TM) 2022 **
** Advanced Engineering Analysis, Design and **
** Optimization Software from Altair Engineering, Inc. **
** OptiStruct includes an enhanced proprietary version of NASTRAN **
** Windows 10 (Build 9200) RL-4015628 **
** 12 CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz **
** 52131 MB RAM, 75096 MB swap **
** Build: 1110680uwn33220_Ce64RB68UH14M:201153-000 46004004000000014 **
** COPYRIGHT (C) 1996-2022 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: C:/Program Files/Altair/2022/hwsolvers/optistruct.cfg.
NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
