Altair RISE
Nominate Yourself Now!
Average temp of volume in CFD Postprocess
User: "avb"
Altair Community Member
Updated by avb
I want to get the average temperature of given volume after running CFD simulation. How can I get the average temp of volume in postprocessing
1 - 4 of 41
    User: "Nagahashi Kouta"
    Updated by Nagahashi Kouta
    Hi, avb
    I'm not familiar with CFD simulation, but I think the operation is the same .
    First, open the result file and plot the contour type (temperature) you want
    Second, open query panel and select the element required, turn on all the query fileds, query the elements' temperature and export the query result to a csv file. Then calculate the average temperature you want.
    Just like the picture below
    User: "avb"
    OP
    Updated by avb
    Hi, avb
    Thanks Nagahashi for your reply. This method is useful but my model is very big and when I try to select all the nodes, hyperview crashes.
    I was looking for some other method.
    But thanks again this is useful for small number of nodes
    Hi, avb
    May I know the approximate number of nodes you are querying?
    The folloeing commands may help you, it deals with about two million nodes in one minute.
    set t 1
    hwi OpenStack
    hwi GetSessionHandle sess$t
    sess$t GetProjectHandle prj$t
    prj$t GetPageHandle pg$t [prj$t GetActivePage]
    pg$t GetWindowHandle win$t [pg$t GetActiveWindow]
    win$t GetClientHandle cln$t
    cln$t GetModelHandle mdl$t [cln$t GetActiveModel]
    set setid [ mdl$t AddSelectionSet node ]
    mdl$t GetSelectionSetHandle node$t $setid
    node$t Add "displayed"
    mdl$t GetQueryCtrlHandle qry$t
    qry$t SetQuery "node.id,contour.value"
    qry$t SetSelectionSet $setid
    qry$t WriteData result1.csv
    mdl$t RemoveSelectionSet $setid
    hwi CloseStack
    The newly generated file "result1.csv" is saved in the current working directory(for example :C:\Users\sakihama\Documents\result1.csv)
    User: "avb"
    OP
    Updated by avb
    Hi, avb
    set t 1
    hwi OpenStack
    hwi CloseStack
    Thanks a lot. This method works!!
