🎉Community Raffle - Win $25
Join and Win
The file name disapears from the right hand corner
User: "Vuk Blagojević"
Altair Community Member
Updated by Vuk Blagojević
Hello, I noticed that in 2021.2 the file name disapears after some time from the right hand corner. When I close the file and reopen, the file name reappears. Is this something that has been fixed in the new version? Thank you.
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    the filename showed there is just a note in HM session. It should be easily turned-on/off from the browser.
    Maybe you're using some command such as 'isolate only' that actually hides everything else, and in your case maybe also the filename note.
    OP
    Hello, how do I show it again after it dissapears? Thank you.
    User: "Subhu"
    Updated by Subhu
    Hi,
    Right click on the Title in the model tree and Click on Show.
    Let me know if this helps
