Hello, I noticed that in 2021.2 the file name disapears after some time from the right hand corner. When I close the file and reopen, the file name reappears. Is this something that has been fixed in the new version? Thank you.
the filename showed there is just a note in HM session. It should be easily turned-on/off from the browser.
Maybe you're using some command such as 'isolate only' that actually hides everything else, and in your case maybe also the filename note.
Hello, how do I show it again after it dissapears? Thank you.
Right click on the Title in the model tree and Click on Show.
Let me know if this helps
