🎉Community Raffle - Win $25
Join and Win
How to contour plot Tsai-Wu failure index for PSOLID MAT9OR in Hyperview ?
User: "Theo Saclier"
Altair Community Member
Updated by Theo Saclier
Hi everyone,
I am working on modeling strength-anisotropy induced by Fused Deposition Modeling (FDM) and more precisely on implementing Tsai-Wu failure criterion. I have defined a MAT9ORT material with TSAI3D criterion (e.g. based on engineering strengths) associated to a PSOLID property. Moreover, I have requested for a FAILURE output in H3D format but when I open the result in HyperView the corresponding failure index is not available in the contour plot 'results type' tab.
I have read other questions related to Tsai-Wu plot in HyperView and the solution for PSHELL was to go through the 'derived results' opening first the model. Is it still the only way to do it ? Does it work also for PSOLID element property ?
Thank you in advance for the help.
1 - 1 of 11
