Move component within Hypermesh tree
Updated by Altair Forum User
HI All,
can you please tell me if i can move the component up and down in model view in hypermesh for better organization.
On my attached file i want o move Aft_Spigot_pin_5 down and Aft_Spigot_pin_4 up.
1 - 6 of
61
Hi Tinh,
can't follow. can you please explain more with picture?
Click on the top most area of the column within model view.(The header)
This should sort the names (ascending/descending)
Thanks Kevin,
suppose i have two assembly explain below
Assembly_1
-component_1
- Component_2
Assemblt _2
-component_3
- Component_4
is it possible to slide component_3 into Assembly_1?
Thanks
Yes, all you have to do drag and drop that component into the assembly of your choice,within the browser
Hi Ray
just click on column header 'Name'
