Altair RISE
Nominate Yourself Now!
MAT4 Question...
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
I noticed today in the MAT4 (thermal properties) section of the materials panel that you can change values for k = and H = . I know that k stands for thermal conduction coefficient but does anyone know what the H exactly stands for? I'm not even sure what units might go with it either. I have searched online for material properties that have the symbol H but no such luck. Is it possible that the variable might be Greek but is substituted as H just for this software? Any help or tips on where to find the answer for this would be much appreciated, thanks!
Dylan Stelzer
                          [:-D]
1 - 7 of 71
    Altair Employee
    OP
    H is the convective heat transfer coefficient: W/m2 C
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    see  OptiStruct > Reference Guide > Input Data > Bulk Data Section:
    MAT4
    Altair Employee
    OP
    Hello Guys...
    Hello Rahul,
    I have doubts regarding Thermal Heat Transfer Analysis. My Analysis is Transient Heat Transfer. So should I take only MAT4 only or Both Mat1 as well.
    My second doubt is I got error message of A dependent d.o.f. of rigid elements is constrained in a SPC Set.
    I used Tut: OS: 1090 Example...
    Please guide me...
    Thanks in advance
    Altair Employee
    OP
    MAT4 card can be activated through MAT1. So you need to create a MAT1 first and within MAT1 use MAT4.
    I answered the same question in one of your other forum post. Please check.
    Altair Employee
    OP
    Thank you for you Reply...
    I also saw one comment from one of your colleague's communication regarding one Question (Rahul Ponginan) and so I only took MAT4 only. Because my guide also told me for Only Heat Transfer Analysis I Need only Mat4....
    Secondary can you just tell me how can I give higher heat Transfer on the top of my Profile and Lower on the bottom? so I can solve my Problem further ...
    Thank you,
    Best Regards,
    Jay
    Altair Employee
    OP
    Nayak Sorry I missed one of your commnets that you are doing only heat transfer analysis.
    If you have only Heat transfer and no structural analysis parametrs, you can just use MAT4 card.
    I will check this and will let you know.
    User: "Gauri Mandekar"
    Altair Community Member
    Updated by Gauri Mandekar
    What's the unit of k thermal conductivity?
