🎉Community Raffle - Win $25
Join and Win
how to apply pressure along hoop direction
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I need to apply pressure along hoop direction on a cylinder. pressure value vary along Z. Z is height of cylinder. And i do like below
Analysis -> Pressure -> equation = z ->Y-axis ->a cylindrical system.
But pressure generated is like below picture, and not along hoop direction, why? how can i do it correctly? thank  you.
<?xml version="1.0" encoding="UTF-8"?>post-5845-0-58135400-1368854030_thumb.pn
woody
1 - 2 of 21
    User: "tinh"
    Altair Community Member
    Updated by tinh
    just ignore  the cylindrical system and switch pressure direction to N1N2N3 (no select == direction is element normal)
    so direction will be centripetal
    Altair Employee
    OP
    Hi,
    i have the same problem, don't know why it doesn't work.
    If you can work with forces, try this. Forces (on nodes) works with cylindrical systems correct...
    Regards,
    Mario
