how to apply pressure along hoop direction
Altair Forum User
I need to apply pressure along hoop direction on a cylinder. pressure value vary along Z. Z is height of cylinder. And i do like below
Analysis -> Pressure -> equation = z ->Y-axis ->a cylindrical system.
But pressure generated is like below picture, and not along hoop direction, why? how can i do it correctly? thank you.
woody
just ignore the cylindrical system and switch pressure direction to N1N2N3 (no select == direction is element normal)
so direction will be centripetal
0 -
i have the same problem, don't know why it doesn't work.
If you can work with forces, try this. Forces (on nodes) works with cylindrical systems correct...
Mario
