Hi Everyone,
 my project is to model a planetary ball mill, and I have some big problem with the rotation of the disk and cylinders.
 These elements should rotate in the opposite direction (as in the picture); however, if the speeds of the disk and cylinders are close to each other, the movement of the cylinders slows down or stops altogether.
This problem does not occur when I change the rotation to the same direction. I think there's something wrong with the reference system but I can't find the error.
 I will be grateful for help.
Iwona
