🎉Community Raffle - Win $25
Join and Win
creation of MonVol
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I want to create monitored volume/gas inside a volume which is consists of only hex element. No shell elements are present.
How can I create MONVOL from solid elements.
Please suggest.
1 - 4 of 41
    Altair Employee
    OP
    Hi Pritam,
    Please create a /SURF/PART set and recall the same while defining the monitored volume.
    You can see the steps for creating monitored volume at: https://www.youtube.com/watch?v=V9qOKGbDA48&list=PL1u26y75SCrA_BOCLaSewVCNY7xRvCTnA&index=5
    Altair Employee
    OP
    Dear George,
    I have seen this tutorial and its of shell element.
    I tried by /SURF/PART, but the problem is, my component consists only solid elements. so when I am extracting set of SURF, surf is extracted on both side of the component (i.e. inside the volume as well as outside of the volume, as it has a thickness), as of i need only extraction only on inside of the closed volume.
    So how to do that.
    Thanking You.
    Altair Employee
    OP
    Hi Pritam,
    You should put shell skin with VOID material to the volume boundaries and then create the /MONVOL.
    User: "Malav"
    Altair Community Member
    Hii Pritam, was your problem resolved by this approach? i am in similar problem right now, and gave void material to shell elements, but error seems to be there so.
