Continuing a NLSTAT subcase in a DTRAN subcase
AndreasMarks
AndreasMarks Altair Community Member
edited January 2024 in Community Q&A
According to the documentation it should be possible. ("Subcase continuation between Nonlinear Transient Analysis and Nonlinear Static Analysis is also supported")
But by linking the loadcases by using CNTNLSUB I get an error message. Also the documentation of CNTNLSUB says that it only works for subcases of the same type...
How do I make it right?
Welcome!
Answers
  • Sriramanuj_16
    Sriramanuj_16
    Altair Employee
    edited January 2024
    Hi Andreas Marks,
    For your situation, the CNTNLSUB should be effective. Could you kindly paste the complete error message here? I have tried it on a sample model, and it is functioning correctly for me. Please review it and share your observations.image
  • AndreasMarks
    edited January 2024
    Hi Andreas Marks,
    Error message:
     *** INFORMATION # 1737
     SUBCASE 3: override ANALYSIS type with DTRAN    (from NLSTAT).
     *** ERROR # 1999 *** in the input data:
     In SUBCASE 3: card CNTNLSUB references wrong type SUBCASE 2.
    Solution:
    I forgot TSTEP and I changed the TLOAD type to LOAD (from Accel even tough I do apply an acceleration)
    --> seems like the error message has nothing to do with my issue?!
  • Sriramanuj_16
    Sriramanuj_16
    Altair Employee
    edited January 2024
    Error message:
    Solution:
    Hope the model is running fine now. Here are the references for selecting the load type option under TLOAD for dynamic load application.
Welcome!
Welcome!
