🎉Community Raffle - Win $25
Join and Win
Meshing complex STL file
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have a problem with a complex component (STL file) that contains different dimension of triangles because there are lattice regions and massive regions. Unfortunatley, i try to use the 'shrink wrap' command, but this creates or little tretra-elements (and after the analysis is very expensive) or big elements(in this case i lose the details of reticular part). How can i do?
I try to convert all the STL file in surfaces using 'From FEA' in surface, but the result is a very irregular surface with a lot of hole.
Thanks
1 - 11 of 111
