🎉Community Raffle - Win $25
Join and Win
Sensibity optimization: Found value of force for a define displacement
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
     As i wrote on the title, i would like optistruct find me the value of the force for a certain displacement.
For example, I a have a cantilever beam (let's says: 3D solid, hexa) and the maximum deflection I would like is:10mm. I would like to make a optimization analysis (i think its a size optimisation)  which optistruct found the force from a range (says: [0N to 1000N]) corresponding to 10 mm of deflection.
     Is it the right type of optimization ( SIZE one)  if yes could u tel me how to make that ? i will be really apreciate
I set up it like that:
  • Objectif: 'find value of force corresponding to 10mm of displacement'
  • Constraint: u=10mm
  • design variable: Force range from [0N to 1000N]
  Thanks by advance,
        Kodebar ^_^/emoticons/default_happy.png' srcset='/emoticons/happy@2x.png 2x' title='^_^' width='20'>
1 - 2 of 21
    Altair Employee
    OP
    Hi Kodebar,
    When you are using solid elements, Size may not be the right type of optimization. Instead use shell elements and use Size.
    here is a forum post which talks about calculating forces when the deformation is known:
    Altair Employee
    OP
    Hi Prakash,
        First thanks you for haved taking time to answer me!  I really, really apreciate!
        I went to your link on the forum, but there is no explaination, and the link in this topic are dead ...We cannot click on the link , and see something about the problem explain....
        However, i make some test since the first post, naturally u were right we can't extract U=f(F) with 'SIZE' method ^_^.
         So, what i ve done is to create multiple loadcollector (for exemple : load collector N°1: Force=5N, load collector N°2: Force=10N, load collector N°3: Force=15N, .....) and post process the results on displacements with hyper view. I created subcase ( CNTNLSUB card).  This method works but i think Hypermesh can do better maybe using hyperstudy ?
         Have u got an idea to make this kind of study: populate automatically the effort on predefined range ( for exemple [5 N to 15N by step of 1N]? Because my methode could be relative cost time depended if i have to populate 50 loads collectors !!
        In additionnal, could u explain me how to create a graph with X axis the effort 'F' (corresponding to subcase in my methode) and on Y axis the maximum  displacement (simple to call this result in hyperview or hypergraph)? I didn't found how to insert 'subcase effort'  for the X axis
        Thanks you, :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:'>
        Kodebar
