Altair RISE
Nominate Yourself Now!
Eigenvector/ characteristic vector
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Is there any possibility to export the eigenvector/characteristic vector from hyperview? i only find the principal values but not the directions of it. Thanks for your help
1 - 3 of 31
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi Niklas
    You can export eigen value and eigen vector individually using HV query panel.
    But if you want to consider the effect of modal analysis for Modal frf case then EIGVSAVE and EIGRETRIEVE option listed in subcase section would help you.
    Check OptiStruct user guide for the detailed information.
    Check the vector option in HyperView also to see the direction of the vector
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.d97acdfc01b13125c980581643f389d0.png
    Altair Employee
    OP
    Thank you,
    but in my case there´s no subcase section or i just cant find it.
    The exact problem i have is that i need to export the pricipal stress with their directions for a crash model, do you know how i could do that ?
    Because, with the quervy panel i can only export the value of the pricipals but not the direction
    Altair Employee
    OP
    Hi @Niklas
    Can you export the component-wise(X, Y or Z instead of magnitude) results from HV and check if that helps?
