quasi static analysis
Hello,
I have completed a dynamic crash analysis on hypercrash and wanted to convert it to quasi-static. The dynamic analysis lasts no longer than 100 ms so I can use a low time-step.
How should I proceed to be able to use radioss for a 2  minute simulation with a higher time step? Is is possible with explicit analysis in radioss or should I use another software?
I changed the velocity to an imposed velocity and I am using no mass in order to make it quasi static. The minimum time step that I am introducing is being ignored when the calculation software starts.
Any advice?
Thanks in advance.
1 - 26 of 261
