Shock Absorber
Hi everyone,
i tried to implement shock absorber in a shock analysis in optistruct.
I use tutorial in order to set non linear tranisient analysis.
I implement with table1d and pbusht the curve ForceVSdisplacement and applying a force i have checked if the the curves is right.
Then i have to checked if my model with this non linear springs has a right answer to established input.
In this case the model is loaded with an initial displacement and a gravity.
Finally i hate to load model with a curves VelocityVSTime.
Now i'm stopped at check problem.
My doubt are:
- the initial dislacement is inserted with IC and TIC in model but in the result there isn't initial dipslacement. Why?
- The tstep is calculated by solver? Is possible have a fixed timestep?
- maybe more simple simulate this problem with a explicit solver as Radioss?
Thank you for the answeres
Hi Prakash,
i agree with you, i have tested also with velocity as TIC, but i don't read this oscillation in my model both with velocity and displacements.
have you modified something?
Regarding Tstep, i have modified Dt on NLPARM but with this parameter i modify only initial time incrmement. i would have costant time increment. is it possible??
Furthermore i have modified also TTerm because my analysis has to last 0.5s.
Thank you for fast answer.
You can use NLADAPT with DIRECT= YES which Adopts fixed time increment. In case of divergence, the run will stop immediately.
Hi,
In your model, I see you have applied Initial velocity and in the results it can be seen,
Did you try with DT on NLPARM?
