How to Pass a Table Name variable within a ODBC Connection?
I have several COM automation jobs where Monarch Classic connects to a data source on an AS400. Usually the connection is hard coded with the Monarch Project. I have a requirement to pass the data source name (e.g. VENAFILE.TABLENAME) where TABLENAME contains the month year (e.g., 0224 within VENAFILE.DSA0224 table name). Is it possible use a dynamically passed the full table name within the COM automation session with an AS400?
The Monarch programmer's guide mentions ODBC connection but does not provide examples. If anyone has experience using user defined variables (specifically data source name) within COM Automation/AS400 sessions, please provide sample VBA or VBScript that I can edit for my purpose.
Many thanks in advance.
Al
Hi Mahmoud:
Many thanks... This almost got me there. I cannot seem to get the Filter to work with the Monarch Model that is called. See my VbScript, below. Should the "CurrentFilter = NV_RECS" be inside the "OpenFile" string?
Sub testDB()
Dim monarchobj As Object
' Try
Set monarchobj = CreateObject("monarch32")
If monarchobj Is Nothing Then
monarchobj = CreateObject("Monarch32")
End If
monarchobj.CurrentFilter = NV_RECS ‘FILTER NOT WORKING???
openfile = monarchobj.OpenDatabase("Provider=MSDASQL.1;Persist Security Info=True;User ID=financntr1;Data Source=BOOKPM;Initial Catalog= BOOKPM", "1financntr49", "DSAT0227PM", "C:\Users\rhoagland\Pitco Foods Dropbox\Rod Hoagland\New_Vena_Automation\Models\Masters_8X\90_NV_Inv_Eval_Test.dmod")
monarchobj.ExportTable ("C:\Users\rhoagland\Pitco Foods Dropbox\Rod Hoagland\New_Vena_Automation\New_Master_8X\NV_ODBC_TEST.xlsx")
'Catch ex As Exception
' Console.WriteLine ("Unexpected error: " & ex.Message)
'Finally
monarchobj.CloseAllDocuments
monarchobj.Exit
Set monarchobj = Nothing
'End Try
End Sub
Your help is very much appreciated. You guys are the greatest!!
Thanks
Al
Hi Mahmoud:
Sub testDB()
' Try
End If
'Finally
monarchobj.Exit
'End Try
End Sub
Thanks
Al
Good Morning Al,
Please make sure you add the filter in the model that you are using in the script, and then add the Currentfilter method right before the ExportTable method.
Sub testDB()
' Try
End If
monarchobj.CurrentFilter = "NV_RECS"
'Finally
monarchobj.Exit
'End Try
End Sub
I tested my code and it worked:
If you have multiple filters you can add it before the exportTable method like the following:
monarchobj.CurrentFilter = "CD"
monarchobj.ExportTable("C:\mo\cd.xls")
monarchobj.CurrentFilter = "dvd"
monarchobj.ExportTable(C:\mo\dvdxls")
Regards
Mo
Hi Al,
You can use the following code to pull data from a database table. I tested this code with Monarch Classic v2023.1. The code export data from table dbo.ClassicJan to an an Excel file (export2.xlsx).
The odbc17-demodb in the connection string is an ODBC that i created on my server, which connects to a database named Demo. The user id is demo.
The dbo.Classjan is the table name within the database Demo.
You need to provide the password in the second argument where i put "your password here".
You also need to create a model in Monarch classic that basically pulls data from database table and displays it in Monarch Classic table view. You can change the table name in the connection string as long as table columns matched in the model.
The ODBC that I created which connects to a Database required a password. If you connect to a database using Windows authentication then you don't need the password.
You can click on the following link and review the Monarch Com Auto documentation:
https://help.altair.com/monarch/programmers_guide/altair_monarch_programmers_guide.pdf
Sub testDB()
Try
End If
monarchobj.OPENDATABASE("Provider=MSDASQL.1;Persist Security Info=True;User ID=demo;Data Source=odbc17-demodb;Initial Catalog=Demo", "your password here", "dbo.Classjan", "C:\Datawatch\ComAuto\Demo_DB_with_odbc.dmod")
monarchobj.ExportTable("c:\mo\export2.xlsx")
Console.WriteLine("Unexpected error: " & ex.Message)
Finally
monarchobj.Exit
End Try
End Sub
Hi Al,
Sub testDB()
Try
End If
Finally
monarchobj.Exit
End Try
End Sub
